TxGearhead's avatar
TxGearhead
Explorer II
Jul 25, 2016
TIE DOWN BAD FIT RAM?
2016 Ram 3500 CC LB SRW, wheel to wheel running boards/steps. I ordered TorkLift tiedowns and installed them. The end that the insert goes into was very close to the step support at the front of the bed. I drove from Houston to Maryland, loaded the Bigfoot, and drove home. No issues. I unload the camper and remove the inserts. Driving around town I hear a big rattle over street bumps. Argh...that breakover bar under the back seat is bouncing off something; no it's not. Maybe it's backseat head rests I crammed under the seat back; no. Trailer hitch ball; no. I roll under the truck and look at the tie downs. They are hard against the step support. Got a wrench and checked...they are tight. So I loosen them up, got a 4.5" angle grinder and took .250" off the step support. Problem solved.
Called Tweety's RV Parts and talked to their TorkLift rep. Yeah your Ram has a long list of notes in the fit application guide. I got on Torklift website and emailed them about the issue. No response yet. Nothing really to do about it. They may need to fine tune the welding fixture and give it a little more angle.
Just a heads-up for those using the same application...
  • Send pics to Torklift too, so they can visualize the problem as well as reading the description you sent them
