sasq40's avatar
sasq40
Tie down extension help
So I'm running a 04 okanagan 811 meant for lb/sb in my lb dually. The issue we had last year was the rear tiedown point would hit my fender if we stuck it there, so to make our vacation we just tied it to the bumper on the tc. Now that I got time I want to do it right and extend my mounting holes. I see torklift makes a part, A7004, but that's alot of money when I can just build the same thing with some flat bar and weld some eyelets on.
Now for my question ha, what thickness do you think the flat bar should be?
  • Umm a little more than flat bar
    https://drive.google.com/open?id=11dn-a7004 instruction shows parts break down.
    I would assume angle used and depending on leg length for thickness to resist few hundred pounds of pull on extended/cantilevered end
    Seen where some folks have used unistrut...
    3" x 1/4" Aluminum angle?
