jaycocreek
Jun 13, 2020Explorer II
So many people use the Happijacks wrong including the guy I bought my truck camper From.. Barrels go down not up and from them......
TCM: That’s another mistake we’ve made as a few scratches on our truck can attest. How tight should the turnbuckles be?
Don: You want to tighten the front turnbuckles until the slack or wiggle is out and the turnbuckle is snug. Put a mark on the hook opposite the threaded rod next to the barrel. Tighten the turnbuckle until a quarter to three-eighths of an inch of the hook is pulled out of the turnbuckle. This compresses the spring giving you about 300 pounds of pressure. Tighten the jam nut to keep it set.
For the rear turnbuckles, also tighten them until the slack or wiggle is out and then tighten the jam nuts to the bottom of the barrels. The purpose of the rear turnbuckles is to keep the camper from bouncing up and down. The side to side movement is controlled by the front turnbuckles.
