silverbullet555's avatar
Jun 09, 2020
Tie-down systems performance/safety vs cost
I have no doubt this has been beaten to death.
Now that we have a new truck camper, I need to outfit the truck to safely carry it. If it matters, the truck is a 2007 2500HD Chevrolet Silverado crew cab 4wd 6.5' bed.
It seems that the torklift stuff is the crème de la crème of tie-downs and they are at the top of my list.
But, I would like to balance cost as well, at least until we know if truck camping is for us. The camper cost us $3K and I am looking at probably $2.5K in truck upgrades if I am not careful. I need to upgrade the hitch so I can run a 24-36" extender to be able to safely tow our boat. That alone will cost me a bit over $1K between the hitch and the truss.
I also plan to do some suspension upgrades with a sway bar and/or airbags.
That leaves tie downs and the truck attachment points. It came with Brophy tie downs which will I will use to get the camper home (5 miles).
I want to balance performance and safety with cost. Safety is always the top consideration, but if two systems are both safe, then cost can come into play. This goes for the tie down points and the turnbuckles to connect the camper to the tie down points.
So, from your perspective, what do I need to consider?
What are safety/performance benefits of torklift over happyjack, etc.?
I want to make a good choice and not overspend or make things unsafe.
  • If you're upgrading your hitch, you could reasonably fab straight bar tie downs for the rear coming out of a Curt or Torklift hitch. Or get just the Torklift extensions.
    Front you could use happijacs
  • I used these 3300-lb Harbor Freight Ratchet Straps to get my free 2002 Lance 811 home....but I don't feel comfortable recommending for highway travel :B
    I'm planning to get a set of the Torklifts to be sure I'm secure going on the beach.
  • You are considering safety versus cost but the other consideration is convenience. How often you will be taking the camper off will be a big consideration. If it is OFTEN then the convenience of the FastGuns will be huge. Will provide safety, plus MAJOR convenience,..but yes,..at a cost.
    I did major truck upgrades to my 2011 F350 to carry our AF811. The last one I did was RideRight airbags,....and I wish it had of been the first upgrade. I may not have needed all the other upgrades.
    One upgrade though shines above ALL others,....going to 19.5 rims so I could get commercial Michelins on my SRW. The rubber is the weakest link I believe.
  • Definitely not Brophy tie downs.
    How are you going to use the camper? Paved streets and campgrounds? Crawling over rocks on trails? The more off-road, the more I would tend to the Torqlift.
    The other thing to consider is how long you intend to keep it and use it. Amortizing over a long time makes the costs come down
