TRAILRIDER125's avatar
Aug 26, 2018
Tie downs and loading
I'm sure this topic is covered elsewhere. But I cannot find it. Could some one please explain to me exactly what I need for tie downs to carry a slide in truck camper on my old dually? Do I purchase and have them installed prior to buying the camper? Do people sell used truck campers along with the required equipment? And can the tie downs be installed by anyone.....for example, me? Or do I go to a shop to have that done. I'll soon be ready to purchase a camper but I don't want to drive a long distance and find out I can't bring it home! Thanks in advance.
  • one other thing if the seller is not carrying the camper on a dually you will need to get the proper swing out brackets for the front jacks so that they will clear the dually fenders.
  • You need the tie downs installed in order to carry the camper. If you have some good mechanical skills and can use basic hand tools and a drill you can probably install either of the two major brands of camper tie downs (Happijack and Torklift).
    These kits are somewhat truck specific so the likelihood of you buying a camper from someone with the same year model and make of truck and using their old hardware is pretty slim.
    You will need both the attachment points that go on the truck as well as the hardware to secure the camper to the attachment points. There are basic turnbuckles or you can upgrade to quicker pivoting/locking mechanisms (Fastguns is one brand).
    It may be rather difficult to find a shop to install the proper attachments unless they are a truck camper dealer. I recently sold a TC and told the buyer what to buy. He went to a non-truck camper RV dealer who told him they didn't know anything about truck campers but that he shouldn't need any of the hardware I told him to get. He believed them rather than me and showed up with nothing!
    By the way, when you go to get your camper leave your tailgate at home. Also, you will likely need a 7 pin connector in the front right corner of your bed OR you will need an extension cable to get from the rear 7 pin by the hitch up to the front right corner of the bed. Most all campers use the standard 7 pin plug except Lance. Lance has their own special 6 pin plug that comes with a wiring harness.
    If you have a plastic drop in style bed liner get rid of it. You will want a rubber bed mat to keep the camper from sliding around. Depending on the model of truck and camper you may need to build a platform to raise the camper up to clear the truck cab. This is mainly a problem with older campers on newer trucks, particularly Fords. Also, tailgate openings have gotten narrower over the years. Again, an older camper on a newer truck can cause fitment problems.
