PhilR's avatar
PhilR
Explorer II
Sep 10, 2018
Tie Downs for 2019 Chevy 3500
Torklift is showing "nothing available" for my Chevy 2019 3500HD crew cab short box diesel 4wd. Does anyone know if the 2018 tiedowns will work on the 2019 truck? Thanks.
  • 996Pilot wrote:
    Call Torklift directly for the answer. Good customer service!
    X2
  • My Chevy dealer has at least one 2019. Its not for sale yet last time I looked but your dealer may let you measure if he/she has one.
  • Go to any competent weld shop and have them build a set to fit. Better yet, build them yourself. Both avenues would probably be cheaper than buying them ready made.
    Nothing there is rocket science at all. Mounting plates, schedule 60 square tubing and some drilling and lynch pins.
    If you have a new truck that has a factory receiver hitch on the back, check and see if there is a square through hole in the receiver. My buddy has a Ford F350 with a factory receiver hitch and all he did for the rear mount was slide an appropriate sized square tube through the hole in the receiver, added screw eyes on the ends and used that for his rear tie down points. He drilled and tapped the square tube on each side of the hitch frame and added bolts to keep it from sliding back and forth.
