dcpac
Jun 04, 2016Explorer
Tie downs?
Can someone explain why I see some trucks with tie downs mounted directly to the frame and others to the bumper and behind the cab? I'm not sure if it is just preference or the what kind of camper/ t...
dcpac wrote:The Torklift fast guns are not the same thing as the Torklift frame mounts.My point being, if the build sheet does not specify Torklift Tie Downs, you might only be getting the Tie-Downs.
... When I ordered it I asked for Torklift fast guns and that is what is on the camper build sheet, so I can safely assume I will have a frame mount.
