Can someone explain why I see some trucks with tie downs mounted directly to the frame and others to the bumper and behind the cab? I'm not sure if it is just preference or the what kind of camper/ t...
He means; "if your build sheet only shows tie downs, you will have tie downs, but not frame mounts, which are installed on the truck you will use to carry your camper.
