Dome's avatar
Dome
Tie Downs
A couple weeks ago i got a set of "Fast Guns"tie downs.
I just got back from a weeks trip to Moab and back. I've got to say these things are the "cats meow". They are high quality and very very easy to use.
Adjustments are easy, no wrenches are need to tighten or loosen the tension.
If you are in the market for a set of tie downs I would suggest you look into this system. Those of you folks that have this product know what I'm talking about.
Steve
  • Nice but we get so ripped off for shipping to Canada, it is like over $100, plus probably paying custom and taxes.
    I bought some cheap load binder, added some chain and turnbuckle, works good and fast but no fancy look! I had them for many years no problem.
    http://www.mfrexpress.com/mini-chain-load-binder-375-lbs-wll-p-279.html
  • Make sure you get a set of locks for them, so they won't wander off when you are away from your rig. Easy for the owner to use, but also easy to remove, very quickly.
  • MN Ben, are you upgrading your TC?
    Dome, sure is a whole lot better than, chains & turnbuckles!
  • I like mine! No more agjusting the turnbuckles evertime I hook up. Load/Unload time is cut down considerably. I am sure I will have these for my lifetime (ie: they dont go with the camper when upgrading).
