I took my Dodge 3500 to the local Dodge dealer for a tire rotation today. They said that they couldn't get the lug nuts loose on the rear duallies. They tried soaking them with penetrating oil but the...
This will not help with the removal but will help the next time you need to remove the tires. Be sure the tire shop has and uses some type on anti-seize product on the studs when installing the new tires. Most reputable tire shops will use one of these products when they install the tires.
