pigbike
Dec 05, 2013Explorer
Tight nuts
I took my Dodge 3500 to the local Dodge dealer for a tire rotation today. They said that they couldn't get the lug nuts loose on the rear duallies. They tried soaking them with penetrating oil but the...
Hannibal wrote:transamz9 wrote:06Fargo wrote:
I like peanuts.
The Big Fight to remove rear wheels is a often overlooked side benefit of a dually.
Consult your local tire experts or the Tire & Rim association before putting anti-seize compounds on wheel mountings regarding getting correct torque values afterwards.
I've never had a problem with a Ram or a GM but the SD lug nuts have a locking devise in them that can be a major PITA. The problem with them is that there is enough play in the nut and locking washer that you loose all the torque the impact has to remove it. On a dually, you almost have to use a long anvil impact to be able to get to the lug nuts. If you use an extension you will loose torque . My 1/2\" drive impact has 1200 ftlb of torque and there are times I have to break out the 5' strong arm to break some of our SD lug nuts loose.
Those aren't lock washers. They're flat washers that require a drop of motor oil between the nut and washer to prevent seizing. Works like a champ. I much prefer them over my previous Ram's lug nuts.
Do long bed crew cabs make less rear wheel torque than reg cab short beds due to the length of the drive shaft? I've never heard of the length of a shaft reducing torque.
I like peanuts.
