Bedlam
Apr 17, 2017Moderator
What people are describing with the Timbrens is similar to the upper StableLoad spring pads - If you have them to too close to your overload spring, any large suspension movement will cause poor ride. Going to Energy Suspension stops reduces problem this because they compress more. I know Timbrens have two different densities of stops available for different loading capacity. The softer ones will be more compliant when contacted while the highest rated ones will resist that compression more. You need to choose your gap and density for the best balance between load handling and unloaded ride - It will be a compromise that needs to set by your conditions and sensitivity.
44,071 PostsLatest Activity: Aug 23, 2026
