DieselBurps wrote:
Spoke with Timbren, they recommend th single convoluted because the double convoluted could 'flip over' on itself. Now I am really confused because it seems most here have the double convoluted.
This is going on a Ram 3500 cab and chassis by the way total camper weight is around 3,500 lbs loaded up.
The only thing that Timbrens maybe concerned about is the double convolute would slip off the axle tube, because there is no flat landing pad on the axle. If you go with the single convolute you can always remove that 1” thick rubber spacer to custom tune the ride and ride height.
