I have had two trucks.
The first was a 2010 Ram 2500. I added Rancho shocks and airbags. The airbags were a serious disappointment. They added lots of sway even at low psi. They leaked and after a couple of years one bag developed a tear and had to be replaced. I had to put the Rancho shocks on a high settings to reduce sway which then made the ride harsh. I gave up with the airbags, added Supersprings and was able to reduce the settings on the shocks. Supersprings also cured the sway issue.
My second truck is a 2018 Ram 3500. It handled the load marginally well except I could not drive at night without blinding oncoming drivers. I added Timbrens for a quick, low cost solution. The ride is still a bit mushy, but OK. If I decide on a further upgrade, I would not bother with the shocks, but I would consider Supersprings. They should help stiffen the suspension and reduce the rear sag even more. Supersprings fix the primary issue and considering what you get and the effect, they are very low cost. You can also save even more by installing them yourself. If not installation cost should be low. They merely bolt on with shackles. They can also be adjusted and they are progressive so they have relatively little effect on driving without the camper. I suppose you could achieve the same by having a spring shop add an extra leaf spring. The expense would be more and you would have to rely on the spring shop to select a suitable additional spring.
