billtex wrote:
.....Timbrens add additional support at the axle-they are somewhat of a “hard stop”. (They are slightly progressive). Many users report a slap when Timbrens engage the axle going over bumps. This is concerning to me in an unladen condition.
Bill
I put Timbrens on my truck about a year and a half ago and have driven almost all that time without any load. The ride has been good. It takes driving too fast over a speed bump or something similar to get any thump from the semi-hard stop. Under normal everyday driving conditions that does not happen. Normal rough roads and tar strips and the like are not a problem. Even without Timbrens hitting a speed bump or pothole is going to give a jarring ride. After all the rear springs are stiff and heavy and do not readily absorb large bumps.
The way the springs are designed on my 2018 Ram 3500, Stableloads would not work well, if at all. I also like the ease of installing the Timbrens. The first installation took all of about 10 minutes while I tinkered with the spacer. The installation on the other side took about 5 minutes. If you wanted to use the truck for any appreciable amount of time without any major loads, it would be easy to remove the Timbrens. But, again, I don't see any reason for that. Mine are on for the life of the truck.
