billtex's avatar
billtex
Explorer II
Jul 26, 2020
Timbrens vs Stableloads
Hi all, hope everyone is have a good summer. I have not yet decided what mods I will do to the new F350 but am still favoring lower Stableloads to reduce sag. I like this approach as they enhance OE suspension and do not effect unladen ride.
I just got back from a week and my buddy I was camping with has timbrens on his F350. The way they are setup the Timbrens are in contact but his upper overload are not yet touching. This did not seem right to me?
Why take the OE suspension out of play?
Seems to me it makes more sense to enhance the OE suspension not over ride it?!
He seems pretty happy with his setup (2003?) which he has been running for many years. He is also not the type of Guy to obsess over these things...
Is this how timbrens are supposed to be setup?
Am I missing something?
Has anyone tired both Stableloads and Timbrens for comparison?
BTW; totally impressed with the new Ford gasser after our first trip. Very pleased with power and economy after 14 years in a diesel. The 6.2 and ten speed averaged > 11 mpg and had NO issues with power in the mountains of NH. These new gassers with ten speed trannys are impressive,
  • MORSNOW's avatar
    MORSNOW
    Navigator III
    I have both, if I was to chose which one was the most beneficial it would be the lower Stable Loads. They reduce sway and help level out my truck. I later added the Timbrens for additional support while towing.
  • You figured it out. Timbrens or you need more capacity. Stable loads if you just need to get your whole suspension in play.
  • We used Timbrens on our '16 Ram 3500 SRW (SRW has no upper overloads) for a short while. They work well to reduce sag, as long as you take the time to optimize the spacing between the Timbren and axle housing. Too much space reduces their effectiveness, too little space harshens the unloaded ride. Unfortunately, our camper is heavier on one side, so we replaced the Timbrens with airbags.
    We found airbags good for sag (plus each side is independently adjustable); however, once they're inflated above 25-30 psi they tend to get "mushy" with reduced side-to-side stability with a 3-4k in-bed camper on-board. Decided to try a set of lower Torklift stable-loads (stainless steel versions). They helped with sag, plus they increased stability because they mount more outboard then the airbags. We've found airbags (at 15-20 psi) and lower stable-loads are a great combination--providing reduced sag and improved overall stability.
  • I had the lowers on my 2018 Ram dually and really liked them. They were nice how you turn them to take them out of play when not needed, and a pin to hold in correct position. Plus now they make stainless.
  • Is it F350 dually?
    I carried camper who scaled up to 6500 lb on my dually and no modification was required. > 12 mpg on the set btw.
    Even when I pulled small boat behind.
