huskyfan68 wrote:
Back to towing travel trailer with 09 F150 with the 5.4
I would like to add something in the rear since I had good luck with airbags in past trucks and campers. I am looking at Sumo Springs vs Timbrens. (which appear to be simpler than airbags)- Anyone have and advice on which one is better?) Just looking for some load stabilization and leveling.
Repost your question regarding a 1/2 ton truck. HD 3/4 or one ton trucks don't help with the OP with his F150 question.
I have the black Sumo's on the wife '16 1500 chevy 4wd short bed truck for pulling my 10k car hauler/7200 lb blue tractor/7' Rhino mower. Make around 9200 lbs on the trailers axles. I load the tractor till about 1040-1100 lbs on the trucks rear axle depending on where I place the tractor.
Even with new Bilsteins the truck had more pogo sticking than I wanted with a WD hitch/friction bars or without. Not even a hint of pogo stickin' now.
I got them from etrailer at their recommendation per my combo use. On the chevy just take the 13mm bolt out of the bump stop and bolt the Sumo plate adapter to that spot. The adapter has a threaded stud pointing down. Spin the Sumo on and its ready to go. To remove the Sumo... jack the back of the truck up about a inch and spin the Sumo off. Install the OEM bump stop with the 13mm bolt. Takes me about 3 min to make the change.
I've used Timbrens but not on a 1/2 ton truck.
