huskyfan68's avatar
huskyfan68
Timbrens vs. Sumos.....
Back to towing travel trailer with 09 F150 with the 5.4
I would like to add something in the rear since I had good luck with airbags in past trucks and campers. I am looking at Sumo Springs vs Timbrens. (which appear to be simpler than airbags)- Anyone have and advice on which one is better?) Just looking for some load stabilization and leveling.
  • I have Sumo’s. Took 3” of squat and made it 1.5”. Installed them and forget they’re there. They only come in contact when camper is hooked up. I forget the rating but they’re the black ones.
  • When I had a leaf spring F150, I added a helper leaf to each side. Don't remember the brand anymore. Super simple install and worked great for years.
    I tried Timbrens on my current Ram 1500. It was a jarring mistake. I took them back off within a week. Sumo Springs come in two strengths I think. I would opt for the softer one.
    Right now I'm considering air bags. Fairly simple install and adjustability are both plusses.
    JMHO
  • I went with airbags, and a dual path compressor. My main reason is the ability to adjust the hieght of the rear of the TV and the front of the coach to get the 6 point stabilizer legs over obstacles when manuvering into a camping spot. With a bluetooth controlled compressor, it works really well.
  • Why not stick with what has worked in the past? It's tough to get much simpler than air bags. JMO of course.
