Atlee
Nov 05, 2018Explorer II
But you are talking about apples and oranges. Goodyear Marathons are NOT the same as Goodyear Endurance. Goodyear, as far as I know, doesn't even make Marathons any longer.
Totally different design, much higher speed rating, and the Endurance tires are made in USA, whereas Goodyear moved the old Marathon production to China.
Also, Goodyear doesn't make an Endurance in Load Range C, only D and E.
WDP wrote:
Neither, I have had catastrophic explosive failures with both. I do use a TPMS and it worked just fine after the tire blew, no indication of a problem before hand. The GY Marathon have 35 complaints thus far for the same explosive failure, mostly the 235/80/16 E.
NTSB Tire Complaints. Running a 10.5K two axle TT. I went with the truck tire 235/85/16 E as the clearance was there. Strongly suggest you consider.
WDP
