bkenobi's avatar
bkenobi
Time to install tires on my truck camper setup
I have a 2016 Ram 3500 LB SRW CTD that is stock (suspension, tires, etc). The truck carries my Northern Lite truck camper (around 4000 lb total payload) around half the time. With the stock setup, the truck is slightly nose up such that I sometimes get flashed at night (it's not that bad, but could be better if I was picky).
I hate the stock Firestone tires (boring, narrow) but they performed ok on road and seemed fine on snowy roads. That said, I want something a bit more aggressive looking and wider in an AT for my next set. I have been told by tire shops that I can fit 34x12 on stock rims without issue. If I want wider (35x12.5), it would require rims and should add front leveling. If I do that, I'd need air bags too.
Anyone with a similar setup want to recommend a setup? If leveling and air make a huge improvement to the ride quality, I'd rather get it done now to open tire options. I don't think going to 35's over 34's would make as much difference as the width.
Thoughts?
  • Why? New tires are current date code and should last for longer than the milage? Is there a retailer selling old stock?
