- DiskDoctrExplorer
stubblejumper wrote:
Would look pretty on a $$$$K motorhome. NOT mine...
Haha...
They have those decorative flower type "washers" or you can use it to mount a wooden bar of hangers on the inside (with wooden plugs over the holes.
I wasn't implying a 3" bare bolt with giant silver washer and nut! ;) - 4AggiesMomExplorerI used the mirror clips on mine. Two years and it is in fine condition.
I just put the screws that came with the clips into the hollow door. I figure if there is a problem I can always go back with some sort of anchors. - stubblejumperExplorer
DiskDoctr wrote:
:h
Mounting the clips to a hollow door?
The most secure method would be to replace the screw in the clip with a through bolt that has a (decent color/fiber/etc) washer on the inside of the door.
Mmmmmm and if the bolts were long enough you could use them to hang a robe or towel on them. Would look pretty on a $$$$K motorhome. NOT mine... - Aadkins101ExplorerRe Mirror Tiles - each one is 12" x 12". I used 8 (side by side and down), but 10 or 12 will work as well.
- DiskDoctrExplorerMounting the clips to a hollow door?
Liquid nails if you like for good measure. - goducks10ExplorerI mounted a mirror on the bathroom door in our 5'er. Used some mirror glue. Looks like It's a lighter mirror but full length. Home Depot has a mirror department near the cabinet section and has several mirror adhesives to choose from.
- LeBoutExplorer
Aadkins101 wrote:
I used a couple of stick on mirror tiles - still holding 8 years later!
How big is each tile? - Aadkins101ExplorerI used a couple of stick on mirror tiles - still holding 8 years later!
- stubblejumperExplorerLot of time problem with liquid nails is that folks don't let it "Tack Up" prior to mounting and it takes a lot longer to dry resulting in the mirror sliding down or not staying in place. After tacking up, if necessary a piece of duct tape overnight usually results in a good seal.
- NJRVerExplorerI installed a full length mirror on our bathroom door.
Used plenty of liquid nails Mirror adhesive AND clear plastic screw in clips.
2.5 years and still holding strong.
44,056 PostsLatest Activity: Nov 19, 2013
