ROBERTSUNRUS
Jun 11, 2015Explorer
SoundGuy wrote:
I mounted this mega size level to the front of our rig using an extreme mounting tape similar to this and the level hasn't moved in the slightest.
I personally wouldn't ever drill any holes in the side of the trailer unless it was absolutely necessary, such as for supporting awning brackets ... for me, an antenna just isn't important enough. That said, if you're going to do it anyway you'd want to screw into studs within the wall and make sure you seal the holes with non sag lap sealant such as ProFlex.
:) Hi, I'm with SoundGuy; I used two sided tape (3M gray or black) to install levels and other items on my trailer. Don't drill into your trailer especially for light weight items.
44,068 PostsLatest Activity: Jun 09, 2026
