portscanner's avatar
portscanner
Tire Advise
Yes, I am probably opening up a can of worms, but what I know about tires will fit in a lug nut and rattle around.
I have 40K miles on the factory tires and the tread is getting a bit thin. So I wanted to start looking around and see what I want to do.
The current tires are:
LT235/80R17 120/117R
load range E
Now the weights:
Front Rear
With TC* 5060 7600
Factory GVWR 5500 9350
* includes passengers, dogs, food, water, propane and beer.
The only thing I definitely want to do is to replace the floppy rubber valve stems with metal stems so I dont have to chase them around on the duallys when I check the air pressure.
Optionally - I am seriously thinking about getting a set of Centramatics. Last truck I had (3/4 ton) had a terrible time getting the wheels properly balanced. Hoping by getting this it would extend the life of the tires and my patience (as I would not be making multiple trips back to the tire store) Not to mention all the good reviews about the product I have read here.
I have no particular desire to buy larger wheels or other items unless I can see a decent ROI on that. I am primarily looking for new tires, and the above two items. The only other questions I have are:
which manufacturer?
should I get different size or rating of tire? If so, which?
More aggressive tread? I dont look to go "off road" however, most of the places I go are unimproved and can get very sloppy when there is rain or snow.
I look forward to a good education!
  • I have the Centramatics on my 2006 Ram. I had to special order my truck and it took 6 months to deliver it. During that time I bought some accessories. When truck came in it has a balance problem. installed Centramatics and problem went away. than I took off all the wheel weights and it was still perfect.
    this truck was my Fulltime driver so I changed out snow tires for a couple winters (I mount my own). at 50K mile mark I bought new tires, again, no balance. Every once and a while I might have a little vibration when I first start driving, but that goes away real quick. Love them and would recommend them to anyone. (but $200 would pay balancing around 20-30 tires).
  • jmckelvy wrote:
    My truck is similar to yours. I had good service with Cooper Discoverer AT3 tires (over 55K miles with tread left). I recently had Michelin LTX MS2s installed. Very smooth and quiet with good traction.
    Any comments on gas mileage on those two tires? I only get 12mpg and I dont want that number to go lower
  • X2 on the Michelin LTX MS2
    I change them out in the winter for a true winter tire
    For an all weather tire the Good year Silent Armour Pros are excellent for traction all year round, but do reduce fuel economy and
    wear faster in hot weather.
  • Judging by the numbers and you description of use just a mild all terrain from a major manufacture with the same or better load index should be fine.
  • My truck is similar to yours. I had good service with Cooper Discoverer AT3 tires (over 55K miles with tread left). I recently had Michelin LTX MS2s installed. Very smooth and quiet with good traction.
  • Hey, I have the same truck as you and a year and a half ago I put on BFG TAKOs for around $1300, but I purchased those on a Navy base and didn't have to pay any tax. They are holding up very well and have gone though 2 winters on them at the ski area I work at, although it wasn't much of a winter this year.
    I like the tires, but my mileage went down 1-2 mpg and the tires just might be a bit too aggressive for what I do. No complaints other than the mpg issue.
    BFG just recently updated that tire and I have only read good things about them. Look on Tire Rack you might find a good tire there.
