Curly2001's avatar
Curly2001
Explorer II
Aug 21, 2020
Tire air pressure question
I have a 2019 Chevy 2500HD that shows on the yellow sticker on the door, air pressure is 80 psi for the rear and 60 psi for the fronts as max air pressue. Should I tow with these or do I need to inflate the fronts higher?
Thank you,
Curly
  • cummins2014 wrote:
    IdaD wrote:
    I tow with mine at 60/80, but generally drop to 60 all around when I'm not towing. Makes the ride nicer and the rear tires wear more evenly at the lower pressure. There's no reason to run the front tires at a higher pressure, the front axle weight doesn't vary all that much regardless of hitch/pin or cargo weight.
    Same here .
    Same here.
    Same here .
  • I tow with mine at 60/80, but generally drop to 60 all around when I'm not towing. Makes the ride nicer and the rear tires wear more evenly at the lower pressure. There's no reason to run the front tires at a higher pressure, the front axle weight doesn't vary all that much regardless of hitch/pin or cargo weight.
