I don’t know why, but on this subject everyone seems to have the need to embellish their story and overstate the problems and the solutions to bolster their point of view…
I read all the horror stories about the ST tire just like everyone else, but most people I meet and talk to in the CG’s are completely unaware of the controversy… then there are many that have reported not having a problem with the ST tire… my own experience is the same, I have never had a ST tire failure even using them on dozens of trailers over many years, and very many tens of thousands of miles…
While I have never owned a horse trailer, my son has had a few of them… I have had many RV’s, cargo trailers, utility trailers, equipment trailers and boat trailers all sporting ST tires and still not one highway tire failure on any of them… the only catastrophic tire failure I have had in the last 30 or so years was a LT tire on my TV…
I DID have the OE tires that came on this trailer have three sidewalls fail but never while I was on the road and they all failed in the first few months after purchase and were replaced by the dealer at the dealers…
Most of the vocal LT advocates argue they have had multiple ST failures and have since learned… I personally believe when one person has that many problems the problems are deeper than just the tire…
Although if were to believe everything you read here, 100% of those that had a failure all religiously took good care of their tires, never over-loaded, never run under-inflated never exceeded the rated speed and are at a complete lose on what could be wrong… BULL…
I am convinced that the failure rate for the ST tire is somewhere near 1% (and that is to high), and no I can’t prove that, it is solely based on my own research of the problem and is my own embellishment I guess…
Here’s the thing, the argument always boils down to two sides arguing points that even if true are not very material to the other side of the argument… this is especially true for trailers with a GVWR of less than 10,000 pounds… there are people that claim to have solved their problem that own bigger heavier trailers arguing with others that have smaller light weight trailers… as though it’s a one size fits all deal…
High end trailers come with LT tires… who, at what are the GVWR’s, and in what size and LR are these tires???
Could it be they have many choices in tire sizes for these high end units???
I would give odds that none of them come on 13, 14, or 15 inch rubber…
I don’t care if we are talking RV’s, cargo, utility, or equipment trailers… with a GVWR of 10.000 pounds or less, I don’t recall any mfg. recommending a LT over a ST tire, or for that matter recommending a LT tire if they do…
the only thing I have seen in the manuals is in the glossary of tire terminology, where they might say a light truck (LT) tire: A tire designated by its manufacturer as primarily intended for use on lightweight trucks or multipurpose passenger vehicles… and might say, may be used on trailers…
Most RV’s , 2 horse trailers, cargo trailers and an overwhelming majority of utility trailers come equipped with ST tires… and all of them under 10,000 pounds have a vehicle placard… This placard provides tire size and loading information… these labels indicate the vehicle manufacturer’s
information including, Recommended tire size, Recommended tire inflation pressure, Vehicle capacity weight or cargo carrying capacity, Front and rear gross axle weight ratings, and are permanent attached near the left front of the trailer…
they also say, to maintain tire safety, purchase new tires that are the same size as the vehicle’s original tires or another, size recommended by the manufacturer… Look at the tire information placard, the owner’s manual, or the sidewall of the tire you are replacing to find this information…
this all follows the NTHSA tire safety guidelines and is hardly a recommendation to use a LT tire by the trailer or the tire mfg.…
