ksbowman
May 04, 2020Explorer II
time2roll wrote:
I covered mine with aluminum diamond plate. You are lucky you did not need to repair any wires or pipes.
This is basically what I did too. I didn't use the checker plate but, used galvanized sheet metal. Either way if you do both sides full length in the wheel wells you will not have this worry again. Took me about 4 hours to measure, cut for a tight fit, repair insulation and screw in the galvanized sheeting. If you do a search on here I did a post with pictures of how I fixed mine a couple years ago.
