downsjh's avatar
downsjh
Tire Blowout Questions
I have a new to me 2010 Keystone Hideout 27bhs. On my second trip, I had a driver yell to me that my tire was about to blow. I pulled immediately, and inspected the tires and checked pressure. No problems. I did notice some undercarriage (black tarp material) was ripped, and I assumed this is what he saw.
On the way home, the driver side tires blew, and started shredding.
Factory tires, 205\75r14, 1760lbs load. Original owners had 2 blowouts, so he upgraded to 205\75r15(1820lbs). These are the tires that blew for me, 2yrs old.
My unloaded weight was 5500lbs on the trailer axle. I don't have a fully loaded weight.
I want to fix this one last time, but how? The 15" tires seems to rub, so I don't want to keep this size. Do I go back to 14" and load D(2040lbs). Or to 205\65r15 light truck tires(1874lbs)?
I have a 10yr old spare on now, so it won't be moving far until I solve this.
Factory:205\75r14, 1760lbs, 26.1"
Now: 205\75r15, 1820lbs, 27.1"
Option1:205\65r15, 1874lbs, 25.5"
Option2:205\75r14, 2040lbs, 26.3"
Not sure if I need to derate load on LT tires on a trailer?
Will I ever be carefree with my tires, or always to expect a blowout? Mine happened on the freeway(75mph speed limit), very small shoulder, driver side, with only my truck jack to use, 2 small kids and wife ready to get home. And I forgot to tighten the lugnuts, so I almost lost the entire tires 5m down the road.
Update: I was traveling 55-62mph. The back front tire blew. Also, I'm open to other tire options
  • In your case, I would choose the Kumho 857. You might do some measuring to see how much room you really do have regarding diameter of tire, and the 195 size might be a better fit than the 205.
    Some trailers simply do not have any extra room above the tire to go to a larger diameter tire than what the factory specified as OE.
  • Keep in mind that higher load rating usually requires higher psi. Make sure your rims can handle the extra psi. I like Maxxis, but if you want to go up in load rating on a 14" rim, FastEagle's option number 3 (Kumho) would be my first choice. These are Euro tires so a 195 would be the equivalent to a 205/75/14. Have them on a 31' boat trailer and my last TT. They have been great.
  • Forget about the Chinese "No Name" ST tires. One is as bad as the next. Maxxis tires seem to have a good reputation on here.
    B.O.
  • In which Chinese province were they made? Get some Maxxis tires and a TPMS. Problem solved.
