This past weekend we had two tires blowout on our way back from the Outer Banks. The same thing happened two years ago and at that time I replaced all 4 tires. So these on this trip were only two ye...
Your listed tire size is "205/75R14C" and are most likely rated at 1760lbs each which is barely adequate (not adequate in my world). You need to upgrade the tire size to at least ST215/75R14 but a 15" wheel/tire swap would be better if it will fit.
