Old-Biscuit
Oct 13, 2016Explorer III
Grit dog wrote:
For sure.
However, the statement "have to replace the tire that didn't blow cause it was overloaded" is absurd in normal conditions.
I'm certain there are conditions that could damage the good tire in that scenario. Driving for days on an overloaded single tire. Tires were old as dirt to begin with. Tires almost worn out anyways. But to say unilaterally that both tires must be replaced in this situation must mean one of 2 things. Either you sell tires for a living or your tire shop LOVES to see you walk thru the door!
OP has a 3500# pin weight in addition to the trucks weight
One tire flat.......for how long/how far???
Regardless other tire was overloaded. Damage was done.
How much????
Replace both especially if tire size is more than 1/4" due to wear on other tire
OR at least have the tire that was overloaded broken down and inspected inside for signs of damage.
Other option is to drive on and wonder when will that tire give out from the damage done from being overloaded
Or do you not think it was overloaded?
