talonhead
Oct 13, 2016Explorer
Perrysburg Dodgeboy wrote:
Glad everything worked out for you. But I have a few questions.
One, are 3500 and up trucks with DRW exempt from the tire pressure motoring systems? If not why didn't your DW say the warning on the dash? If any of my tires are under 34 psi a warning chime goes off and the DIC puts up a warning saying "LOW TIRE PRESSURE" with the tire location.
Second, as was noted if you are running heavy and continue driving with only one of your dual's you had better replace both tires. You could end up buying all four rear tires if they are more than 30% warn.
Also those two extra tires do you no good if a front tire blows out, just saying.
Don
Ram DRWs have TPIS Tire Pressure Information System. It displays the 6 tire pressures on the EVIC. There are no "Warning" indications, just info.
