transamz9
Oct 17, 2016Explorer
blofgren wrote:mkirsch wrote:Old-Biscuit wrote:
Not ALL safe towing requires a dually
No one said it did.
However there is something to be said for having an extra inflated tire to help you carry and control the load when one goes flat, overloaded or not, rather than no tire at all.
Exactly my way of thinking. I would not want to blow a rear tire on a SRW truck with 4k lbs of pin weight!
The other advantages to a dually are the ability to run a lower pressure giving the truck a better ride, much cooler tire temps in hot weather, and MUCH less tire wear when towing.
I have blown a rear tire loaded. You know what I did? I pulled over to the side of the road and changed the tire and went on my way.
Running a dually's air pressure lower only gives you a better ride than when you have the dually's tires air to max. It don't give you a better ride than a SRW.
"MUCH less tire wear" ? Really? I have ocean front property in Arizona to sell you. You better hope you are getting 160,000+ miles out of your dually tires. LOL
