bkenobi wrote:
...Ideally something quicker to install would be better since I dont expect to use them regularly enough to get practice....
I have been pretty happy with the chains from Les Schwab (a Pacific NW tire shop chain for those located elsewhere). IIRC, they will sell you a set of chains for around $100 or so. If you do not open the carrying bag, you can return them after the snow season for a full refund.
I ended up getting surprised back in 2014 when I was in Eugene, and coming home to NW Oregon. I failed to note that the snow was coming from the south and thought I had plenty of time to drive home. Thus I had the car and not the truck. Ooops. All the freeways were dead stopped, so I took the back roads up the valley. The chains broke outside of Corvallis, so I went to the south Les Schwab that repaired them. That repair lasted until the north Corvallis Les Schwab, where I bought a new set that got me home. I left the old set with them to repair and stopped back there a few weeks later. They couldn't repair them so they handed me a new set. By coincidence they also fit the front tires on my Kubota tractor, so no complaints.
Yes, they are quick & easy to install. Do a test run before the snow hits to figure out the system. Once I learned how they worked, it is a no-brainer install.
HTH,
-Eric
