Sjm9911 wrote:
You have the tandom axel, get the trailor aid or just block up one wheel untill the other gets off the ground. . Your not moving so not really stressing the other side. If it was a problem they wouldn't make them. Carry a bottle jack as a back up.
I have read that the trailer aid does not work if you have the tandem leaf springs. I ended up buying the 3 ton jack from Amazon. it will be here on wednesday so hopefully it is a good jack. I leave on friday so if it doesn't work I'll just go to walmart and pick up a bottle jack for the trip.
