Aka the breeze wrote:
2015 F350 crew cab 4x4 srw 275/65/R20 with the 6.7.. towing my fifthwheel at 15k loaded.. just switched tires and getting a TON of tread/lug flex . .
Truck never had this before the new tires.. talked to the alignment shop, had the front end aligned ( wheel was pointing to 2 oclock going straight) The ownwer had the same exact tires Nitto Terra Grappler G2 and said he had the same problem . .
Any brand in particular I should look for? tire guy is telling me Sumitoma gets great reviews... I had Michelin on and could not wait to remove them.
I hot a nice set of half wore out Firestones that will fit perfectly I'll trade you straight up and I'll deal with the tread squirm.....these tires are rock solid! Lol
Honestly, every more aggressive tire I've had is a little squirmy at first. Some more than others I suppose, but never felt like it was horrible or weird and it goes away as the tires begin to wear a bit.
This is normal.
