Aka_the_breeze's avatar
Jun 23, 2017
Tire flex
2015 F350 crew cab 4x4 srw 275/65/R20 with the 6.7.. towing my fifthwheel at 15k loaded.. just switched tires and getting a TON of tread/lug flex . .
Truck never had this before the new tires.. talked to the alignment shop, had the front end aligned ( wheel was pointing to 2 oclock going straight) The ownwer had the same exact tires Nitto Terra Grappler G2 and said he had the same problem . .
Any brand in particular I should look for? tire guy is telling me Sumitoma gets great reviews... I had Michelin on and could not wait to remove them.
  • I switched to Michelins to get rid of the sidewall flex.
    Check the pressure. The tire shop had my tires at 60PSI, I had specifically asked for 80PSI. All 6 tires were at 60, it felt a lot better with them at 80PSI.
