rbpru
Mar 31, 2017Explorer II
I changed from load range C (50 psi) to load range D (65 psi) tires.
The new tires said that they could be operated at 50 psi, at a reduced load range C rating. Why one would do this I do not know. It did not strike me as too bright to run the tires at under their normal D rating.
I have always kept the my TT tire at their recommended pressure and the 2010 China bombs that came with my used TT had almost 7 years on them when I traded up because of their age.
I would much rather replace a tire because I worn the center tread out then replace it because it failed from under inflation.
