Huntindog
Mar 31, 2017Explorer
Lynnmor wrote:We have a winner!
I'm waiting to hear the brand of tire. Since a load range C has the capacity to carry the trailer at 50 psi, a load range D will carry that load as well. Yes, I would get closer to the 65 psi, but that is not the entire issue here.
I just put new tires on my Camaro.. Stock sizes.
The placard says 30 PSI... The max PSI on the sidewall is 51 PSI.
The proper PSI is what ever the placard says. The tire manufacturer has no idea what the tires will be installed on.... That is why the sidewall max is most always higher than the placard states.
Now having said that, the problem is likely the junk ST tires on the TT.. Lots of reading on the subject, and I won't rehash it all here.
I will just say that quite a few of us have moved on the LT tires, and no longer worry about tires.
Good luck on whatever you decide to do.
