jmckelvy
Oct 09, 2017Explorer
Tvov wrote:
Usually tire pressures are more in the rear. Is that right? and/or is that due to using air bags?
Not necessarily. With a dually no. SRW probably but should get actual weights.
My AF990 fully loaded adds less than 200 lbs to the front but the Cummins engine is heavy so there is a lot of weight up there to begin with. I run the fronts between 75 and 80 psi. Loaded my rear axle weight is right at 8000 lbs. I run 65 to 70 psi in the rears.
You do not need to inflate the rear tires to 80 psi on a dually unless you are REALLY heavy.
