work2much
Oct 09, 2017Explorer
hedgehopper wrote:
Recently, we have been running 80 psi all around with our10-2 Northern Lite on our Dodge dually diesel. This is more than the recommended pressures from the tire loading charts. However, I like the increased stability the higher pressures provide. And higher pressures provide better fuel economy. The tires will probably wear more in the center of the tread. And yes, the ride is a little rougher. But we are willing to live with that.
We do the same. 80 psi, tires max recommended pressure. So far the only uneven wear has been the front outers. Looks like rotation will be every 5,000 miles to get the most out of these stock Nexen brand tires.
