Kayteg1
Oct 10, 2017Explorer II
Reddog1 wrote:
If you have the factory tires and wheels, I suggest you use the PSI as stated in your trucks user manual or the door decal.
If you have aftermarket tires, of a different size than factory, use the tire manufactures recommendation.
I think it is worth noting, you are driving a truck, not the family car. It will ride differently with and without a TC.
Wayne
Door decal on 1-ton trucks shows the pressure recommended for 1-ton load.
When you load 3 tons, this is going to change.
