peirek
Aug 12, 2013Explorer
BurbMan wrote:
I went with the Dill TPMS System. Dill is the company that makes many of the auto OEM systems and makes a good product. The sensors mount internally so are more secure and less prone to damage.
The added benefit to internal sensors is that they read tire temperature also. I can see not only the pressure in each tire but also the temp of each tire, which is helpful in identifying possible bearing and other heat-related issues.
You can get the system at The Tire Rack.
I had the install done by a local tire chain store when I bought new tires. They charged me $2/wheel to install the TPMS when they mounted/balanced the new tires.
I am surprised I missed this option..... I went with the TST and metal valve stems. Had the tires balanced with the sensors installed. My TST gives me pressure and temperature.
44,056 PostsLatest Activity: May 04, 2014
