bobndot
Mar 17, 2016Explorer III
Hector Bravo wrote:
Am I correct that I'd want to replace my rubber stems with metal before adding pressure monitoring? I was told rubber stems might not take the additional forces if the screw-on monitors.
I was thinking about this too. I don't know the answer but I would be concerned about corrosion. Combining dissimilar metals is my thought, causing corrosion. Premature wear or malfunction ?
I would think any two metals that come in contact with each other should be the same metal.
All I can find on the topic is OEM monitors where dissimilar metals can be an issue. IM not sure about after market items.
tire monitor migraines
44,056 PostsLatest Activity: May 04, 2014
