- Hector_BravoExplorerAm I correct that I'd want to replace my rubber stems with metal before adding pressure monitoring? I was told rubber stems might not take the additional forces if the screw-on monitors.
- My last tire issue the tread came clean off. No loss of pressure.
- ROBERTSUNRUSExplorer:) Hi, definitely not; We don't need another paranoid gauge to watch while having a great time traveling. My last trip was a cross country trip and my tire pressures were set at home. We were gone for 3 1/2 months and for over 13,000 miles.
I do visually check my tires and hitch at every rest stop, every gas stop, and every camp ground. Eleven years, many thousands of miles, and never used my spare tire. - GrandpaKipExplorer IIWe have the 507 also. The reassurance while traveling is nice. Turn it on first thing in the morning to check pressures. If they all read good ( which is usual) I don't have to check each one individually.
- BB_TXNomad
Inthecountry wrote:
I should also say this is for a living quarters horse trailer and that I don't go further than 2- 2 1/2 hours away at any time and I only travel on regular hwy's or back roads to get where I want to go. And to be honest, my most traveled place is under an hour from me. I have four tires on the trailer.
That certainly minimizes the need for a TPMS. For those of us who may travel 8-10 hours and 500 or more miles in a day, it becomes more important. A lot can happen in a period of several hours of continuous driving at interstate speeds. - hbradyExplorerI hemmed and hawed about TPMS but my 3 planned trips this year are all within 3 hours from home, I also have new tires. No doubt they are justified on long trips but I'll roll the dice and keep an eye on them the old fashioned way. If I didn't have insurance, I may reconsider.
- bobndotExplorer IIITPM's can be worth it if they prevent a blowout. It's $400 insurance and probably money well spent. Some people have tire issues and some never do, using the same brand, age and size tires. This leads many people to think, maybe there is another factor involved.
I would make sure the trailers weight is evenly distributed over all four tires (put the axles/tires on a scale individually). Overheating and low psi is the main cause for tire failure.
( I have asked motor carrier police to put my rig on a scale for me , to see if i'm safe. They did it for me without hesitation. They use individual scales under each tire )
If you notice the position of axles on various models of trailers, you will see how some axles are in the middle of the frame and others are more rearward. I would think that has an affect not only on tongue weight but tire weight as well. Personally, All my trailers (I have 4 on the road right now) are all rearward axles and they tow very well. I have had one tire failure in 40 yrs. when I forgot to air them up . TPM's would have helped me then . - pawpaw47ExplorerHere'a another vote for the TST 507 system. It's really nice to take a look at the pressures and temps while traveling and not have to worry about what's going on back there. I wouldn't travel without it.
- dodge_guyExplorer III do not use them. just check/set the tire pressure before a trip and during if a long trip (tires should be visually inspected anyway). TPMS will not show a shifted belt that will blow out with no warning.
- InthecountryExplorerhttp://www.amazon.com/gp/product/B00EHHV2OU/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687742&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B00C546H6U&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1WENYMV0VBX1Y9B36WSH
I take it that this is the one?
I'm not sure it's needed as much as those of you who are traveling across America?
I know that blow outs can happen anywhere.
The unit suggested was about $100 more than I thought it would be so have to take a deep breath and think is my kind of traveling worth it?
44,055 PostsLatest Activity: Dec 23, 2025
