rbpru
Feb 28, 2016Explorer II
Tire pressure on the road.
My F-150 specifies 32 psi cold in the tires. While around town with little or no load in the bed, it makes for a comfortable ride. Towing a TT it feels a bit squishy. Since the "P" tires are stamped 44 lbs. maximium, I have found that 40 psi cold does a nice job.
Leaving Indiana for a trip to Arizona I filled the tires when the air temperature was 19 degrees. The TV tires were filled to 38 psi cold and the 65 psi load range "D" TT tires were filled to 60 psi because I figured to be in warmer temps in a day or so. Sure enough in MO with temps in the 40's at night the tire pressure right on TV 40 and TT 65 psi.
The surprise came when we hit an 80 degree two day warm and sunny spell in OK with temps in the upper 50's at night. I have no idea what the pressure was while driving but in the morning before leaving the TV tires were at 55 psi and the TT tires at 75 psi. I dropped them back to 40 and 65 psi and they have stayed there through the warmer mornings in AZ.
During the day I am not surprised by a 5 to 7 psi change while towing but I was surprised by the in pressure when going from 20 degree mornings to 60 degree mornings.
It should be interesting to see what happens on the way back to Indiana.
The question is; Is this typical for those who tow across contry in weather extremes?
