TCCamperNoob wrote:
Hi All, I'm new to all this truck camper stuff. I recently went out on the road and had my tires filled to Ford/tire requirments cold (75 rear, 60 (front). All said and good, right? However, on the road my tires got up over the max pressure of 80psi, like 81-82. Is this normal or should I set cold temp lower? I'm using Wildpeal A/T3W tires LT275/70R18. Any advice would be appreciated. TIA
For about any truck camper you will want to run the rear at the sidewall max. Best to get on a scale to compare to the RGAWR and the tire inflation chart. Is that an oversize tire or OEM size?
