Community Alumni
Apr 11, 2017Contact the manufacturer and see if you can get the inflation chart for the tire. This chart will tell you what weight can be supported by the tire at different PSI levels. If you're not running anywhere near the capacity of the tires then you can run lower pressures. However, 12" tires typically don't have that great of a capacity rating; around 900-1,500 lbs per tire. You may end up having to run them at 80 PSI just to support the weight on top of them.
44,056 PostsLatest Activity: Jan 12, 2020
