BMW442
Nov 05, 2014Explorer
Tire Pressure?
Gearing up for our first trip. Do you usually top off the tires after loading camper? Set them at or just under max cold psi?
jadatis wrote:
If you give needed data , I will give a picture of my filled in spreadsheet in my answer with adviced pressure for your situation.
Tires deform; they don't compress, so the air pressure remains the same regardless of how much weight you put on them.
mkirsch wrote:
Before or after you load, doesn't matter. Tires deform; they don't compress, so the air pressure remains the same regardless of how much weight you put on them.
deltabravo wrote:
I put them at the PSI that is indicated on the door jamb sticker, which for my DRW 09 Silverado is 66 PSI front and 60 PSI rear, stock tire size.
