kaydeejay
Apr 25, 2015Explorer
Gdetrailer wrote:What "constant adjustment"?:h That is rather extreme!
......To me, not worth the hassle with constant adjustments in pressure..
Only time I make any adjustment is when my TST system tells me my tires are not:-
Truck front - 45psi
Truck rear - 70 psi
Trailer (all 4) - 50psi
The Max sidewall pressures of those are 80psi/80psi/65psi respectively.
So no, I do NOT run at sidewall max pressure. These pressures are what the tire tables say are required to support the truck and fiver at each one's GVWR.
44,066 PostsLatest Activity: Apr 10, 2026
