Ok, the sticker on the side of my TT states the tires should be filled to 50 psi. Every time I take it to the dealer I get it back with over 70 lbs psi in the tires. Anyone have this happen to them on...
Be sure that you are checking the pressure with the tires cold. Also, double check your gauge against a known good one.
I find it nearly impossible to get quality work done anymore. I took my truck to the dealer for a balance issue and they left air out of the tires. It was nearly 100 degrees and the tires were hotter yet. When they cooled the pressure was 8 lb too low.
