ken07734
Sep 06, 2013Explorer
Tire Pressure
Ok, the sticker on the side of my TT states the tires should be filled to 50 psi. Every time I take it to the dealer I get it back with over 70 lbs psi in the tires. Anyone have this happen to them on...
ken07734 wrote:
Well, the tires came with the trailer when I bought it and the trailer is new. I assume (and I will double check) that the manufacturer would not install tires that are outside the specs of what is stickered to the side of the trailer. I always check them cold and I have used several gauges to make sure they are correct. The sticker says to fill max to 50 psi. I found (cold) that the tires were at 70 all around. I'm not getting why the tires would be filled past what the manufacturer requires. On my Truck it says 35 all around, I fill it 35 all around and the tire light stays off.
